Voici le journal d’erreur:
Enregistreur: homeassistant.components.automation.nouvelle_automatisation_2
Source: helpers/script.py:526
intégration: Automatisation (documentation, problèmes)
S'est produit pour la première fois: 18:04:40 (1 occurrences)
Dernier enregistrement: 18:04:40
Nouvelle automatisation: Error executing script. Unexpected error for call_service at pos 7: Too many requests, try again later
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 526, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 764, in _async_call_service_step
response_data = await self._async_run_long_action(
...<9 lines>...
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 727, in _async_run_long_action
return await long_task
File "/usr/src/homeassistant/homeassistant/core.py", line 2802, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2845, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1007, in entity_service_call
single_response = await _handle_entity_call(
hass, entity, func, data, call.context
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1079, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 1084, in async_service_temperature_set
await entity.async_set_temperature(**kwargs)
File "/usr/src/homeassistant/homeassistant/components/overkiz/climate/atlantic_pass_apc_zone_control_zone.py", line 400, in async_set_temperature
await self.executor.async_execute_command(
...<2 lines>...
File "/usr/src/homeassistant/homeassistant/components/overkiz/executor.py", line 102, in async_execute_command
exec_id = await self.coordinator.client.execute_command(
...<3 lines>...
File "/usr/local/lib/python3.13/site-packages/backoff/_async.py", line 151, in retry
ret = await target(*args, **kwargs)
File "/usr/local/lib/python3.13/site-packages/pyoverkiz/client.py", line 699, in execute_command
response: str = await self.execute_commands(device_url, [command], label)
File "/usr/local/lib/python3.13/site-packages/pyoverkiz/client.py", line 730, in execute_commands
response: dict = await self.__post("exec/apply", payload)
File "/usr/local/lib/python3.13/site-packages/pyoverkiz/client.py", line 937, in __post
await self.check_response(response)
File "/usr/local/lib/python3.13/site-packages/pyoverkiz/client.py", line 992, in check_response
raise TooManyRequestsException(message)
pyoverkiz.exceptions.TooManyRequestsException: Too many requests, try again later
