bonjour à tous
arrivée depuis peu sur ha, je l’apprécie de plus en plus et le forum encore plus
voilà je voudrais mettre à jour son firmware, mais j’ai du mal à trouver comment faire.
pourquoi je veux mettre à jour, car zigbee2mqtt plante régulièrement et j’ai des message d"erreur, car encore en paramétrage « adapter: ezsp »
voici ci-dessous un extrait du journal :
[11:28:39] INFO: Preparing to start...
[11:28:39] INFO: Socat not enabled
[11:28:39] INFO: Starting Zigbee2MQTT...
[2024-12-29 11:28:45] warning: zh:ezsp: 'ezsp' driver is deprecated and will only remain to provide support for older firmware (pre 7.4.x). Migration to 'ember' is recommended. If using Zigbee2MQTT see https://github.com/Koenkk/zigbee2mqtt/discussions/21462
[2024-12-29 11:28:46] error: zh:ezsp:ezsp: Connection attempt 1 error: Error: Error: I/O error, cannot open /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_566850d8b40eef119d50b62a433abf1e-if00-port0
[2024-12-29 11:28:51] error: zh:ezsp:ezsp: Connection attempt 2 error: Error: Error: I/O error, cannot open /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_566850d8b40eef119d50b62a433abf1e-if00-port0
[2024-12-29 11:29:01] error: zh:ezsp:ezsp: Connection attempt 3 error: Error: Error: I/O error, cannot open /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_566850d8b40eef119d50b62a433abf1e-if00-port0
[2024-12-29 11:29:16] error: zh:ezsp:ezsp: Connection attempt 4 error: Error: Error: I/O error, cannot open /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_566850d8b40eef119d50b62a433abf1e-if00-port0
[2024-12-29 11:29:16] error: z2m: Error while starting zigbee-herdsman
[2024-12-29 11:29:16] error: z2m: Failed to start zigbee
[2024-12-29 11:29:16] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-12-29 11:29:16] error: z2m: Exiting...
[2024-12-29 11:29:16] error: z2m: Error: Failure to connect
at Ezsp.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:364:19)
at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:186:13)
at EZSPAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:152:16)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:161:27)
at start (/app/index.js:154:5)
[11:29:17] INFO: Preparing to start...
[11:29:17] INFO: Socat not enabled
merci de votre aide.
